I have a 99 323i automatic. Manufactured in December of 1998 in Germany. Sold in Canada.
I have a green sticker on bottom of transmission tank.
It says, only use BMW oil part number 8322000212 (perhaps last digit missing, hard to read. maybe 83220002121).
"Other fluids will cause transmission damage"
I can't find this oil via online searches.
What transmission do I have and what oil do I need? I'm not doing a flush. Just drain and fill with new filter.
According to one thread:
Looking at stores, I get recommendations for both 7045E and 8072B. I'm also told by the same stores to not mix 7045E and 8072B or will fail transmission. And I'm also recommended stuff like liqui molly 1200 which states at it meets both 7045E and 8072B standards (and like 50 others). How can this be when mixing 7045E and 8072B causes trans failure?
https://www.fcpeuro.com/products/automatic-transmission-fluid-atf-toptec-liqui-moly
But part numbers don't match. Not sure this is accurate.
Anyway, I really would appreciate some help figuring out which trans I have and which oil I need so that it is 100% for sure compatible with the original oil because I don't want to flush due to age of vehicle.
