1 - 5 of 5 Posts
Vendors - here's what I want to accomplish with this thread - there are people on here who are interested in determining what kits they can use and still pass OBDII-based emissions testing. For example, I'm in NY, and I don't "know a guy" so any upgrades would have to be compatible. Additionally, I'd like to list whether the kit would likely pass stock smog levels as well. I will start with what I know (or think I know!)...
330 / M54 Engine:
<table border="1">
<tr>
<td><b>Manufacturer</b></td>
<td><b>Kit Name</b></td>
<td><b>Kit "Level"</b></td>
<td><b>Kit type</b></td>
<td><b>OBD-II Compliant</b></td>
<td><b>Will it pass emissions?</b></td>
<td><b>Factory ECU?</b></td>
<td><b>Control Strategy</b></td>
</tr>
<tr>
<td>Active AutoWerke</td>
<td>E46 330i Supercharger Kit</td>
<td>Level 1</td>
<td>Centrifugal Supercharger</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>MAF?</td>
</tr>
<tr>
<td>Level 2</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>MAF?</td>
</tr>
<tr>
<td>ESS</td>
<td>TS</td>
<td>Stage 1</td>
<td>Twin Screw Supercharger</td>
<td>Yes</td>
<td>Yes, CARB Approval Applied For</td>
<td>Yes</td>
<td>MAF</td>
</tr>
<tr>
<td>ESS</td>
<td>TS</td>
<td>Stage 2</td>
<td>Yes</td>
<td>Yes</td>
<td>Yes</td>
<td>MAF</td>
</tr>
<tr>
<td>ESS</td>
<td>TS</td>
<td>Stage 2+</td>
<td>Yes</td>
<td>Yes</td>
<td>Yes</td>
<td>MAF</td>
</tr>
<tr>
<td>ESS</td>
<td>TS</td>
<td>Stage 3</td>
<td>Yes</td>
<td>Yes</td>
<td>Yes</td>
<td>MAF</td>
</tr>
<tr>
<td>Technique Tuning</td>
<td>Turbo Kit</td>
<td>Stage 1</td>
<td>Turbocharger</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>MAF?</td>
</tr>
<tr>
<td>Turbo Kit</td>
<td>Stage 2</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>MAF?/ Alpha-N?</td>
</tr>
</table>
M3 / S54 Engine:
<table border="1">
<tr>
</tr>
<tr>
<td>E46 M3 Supercharger Kit</td>
<td>Level 1</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>MAF?</td>
</tr>
<tr>
<td>Level 2</td>
<td>Yes</td>
<td>Yes?</td>
<td>Yes</td>
<td>Alpha-N</td>
</tr>
<tr>
<td>HPF</td>
<td>Turbo Kit</td>
<td>Stage 1</td>
<td>No</td>
<td>Yes?</td>
<td>Yes* (1)</td>
<td>Speed Density w/ Closed Loop Wideband</td>
</tr>
<tr>
<td>HPF</td>
<td>Turbo Kit</td>
<td>Stage 2</td>
<td>No</td>
<td>Yes?</td>
<td>Yes* (1)</td>
</tr>
<tr>
<td>HPF</td>
<td>Turbo Kit</td>
<td>Stage 3</td>
<td>No</td>
<td>No?</td>
<td>Yes* (1)</td>
</tr>
</table>
1: Factory DME / ECU controls throttle bodies and Idle Air Control. Standalone ECU controls fuel and spark, as well as things like VANOS. Factory DME also controls cluster?
As I put this together, I realize that there's a lot of unknowns in the table, hence why I need the vendors help to fill it in more...
Also if a moderator could help me figure out why there's so much blank space when putting in tables, that would be great, or suggest a workaround..thanks.
-Matt
ALL ESS Twinscrew Stages have the following results:
OBD-II Complaint? Yes.
Will it pass emissions? Yes.
Factory ECU? Yes.
Control Strategy? MAF.
Will it even pass visual? 90% Yes if using OEM Airbox.
Discussion Starter #3
Factory ECU? Yes.
Thanks. Updating that now. Hopefully someone from ESS will confirm, but as you are a user of the stage 3 kit, you're also qualified to answer. ;-)
-Matt
Discussion Starter #4
Bump.
I am going to say right away I have less info on the M3 then the 330 (I have a 330 so I'm more interested in that), but I've attempted to add some more info on for AA products.
-Matt
Both of the TT turbos use a MAF and should pass the sniffer (depending on the limits) as they include a new cat.
All supercharger kits should pass the sniffer assuming cats are left in place or new cats installed if running headers.
1 - 5 of 5 Posts
