1 - 9 of 9 Posts
Hey Fanatics,
2005 330ci ZHP with 108,200 miles. Just replaced my fuel pump with a VDO one from rockauto at 107850 miles. The original one died in a fairly weird (to me) fashion - wouldn't prime sometimes, then wouldn't prime at all and would crank forever but would still start, then one time I filled the tank and drove it home and it didn't start the next morning. This differs from the posts I read about people who have sputtering pumps, etc.
After the pump replacement, it started right up. I filled it up for the first time since pump replacement yesterday and drove to dinner. Started ok after dinner, then went to a friend's house, and after it sat for an hour I went to start it and it turned on then immediately died. Started it a second time and it turned on and died. Wasn't responsive to throttle input during this time and would die even if I floored it. Started a third time and giving it gas worked, and it stayed running. Pump might've sounded louder than usual but not sure. I originally diagnosed the stalling on start to a camshaft position sensor which I'm glad I didn't order.
Drove it home, parked it, and it won't start today. Pulled the plug to the pump, 12 volts on 2nd position and ~11.5 when cranking at the plug. This theoretically should bypass me having to look at the fuse and relays, right? Video attached for entertainment purposes.
Anyone have a pump die so soon? What should/may I want to look at for why my E46 is a fuel pump serial killer? Is there any relevance to the fact 2 pumps have died after a full tank?
Thanks!
2005 330xi, Jet Black w Black Interior
I just replaced mine with a Bosch from FCP Euro. Been working like a champ.
2004 325xi, 2000 323ci, 2012 135i
Also, if you have not replaced the fuel filter already it probably is not a bad idea. A clean fuel filter can prolong the life of a new fuel pump. Fuel pumps like having good flow.
Your situation however sounds like a defective pump out of the box.
Swap the fuel pump relay with the horn relay. Yes, yes, you have the correct voltage but remember electric motors run on watts. A watt is 1 volt pushing 1 amp of current.
2004 330i
Vdo should be legit ,different source now ?
Premium Member
Every now and then a quality brand can suffer a premature failure. I find this a little more so since the advent of Covid and the multitude of issues that surround all of that..,. :mad:
Discussion Starter · #9 ·
Fuel filter was just replaced. Fuel coming out was nearly black but it was the original fuel filter. Vent line was in good condition. Based on what I saw in the tank it doesn’t have a bunch of debris in it.
When I go put the new pump in I’ll need to check the screen feet on the failed pump but I expect them to be nice and white and clean.
Hard to believe it might’ve been a defective pump because it did work for a few days but I’m hoping it was just
I’ll have to do this later. I attempted to do this the first pump failure but when I removed the glovebox, footwell light piece, and undid the 2 10mm screws holding the white plastic grid with the relays in it in, I couldn’t get the relay panel to come down within reach.
Have you been in the relays before? Any tips to what I might be missing to get the relays accessible would be appreciated. Or if I just need to try to get at it in its current position I could try that too.
thanks!
1 - 9 of 9 Posts
