Hey guys, I'd like to get your opinion on a problem that seems to be getting worse on my E46.
*UPDATE* I just ran my codes again and am getting a P0171 - Powertrain Systme too lean (Bank 1). It's a pending fault, and no CEL.
Car:
2004 325CI Coupe
M54 Engine
5-speed manual
203,000 miles
Problem:
No CEL, but at low RPMs in 3,4,5th gear, and about 50-75% throttle, I get a surging/bucking in the 2,000-3,500 rpm range. It feels almost like a misfire. If I drive normally, it is almost unnoticeable. Idles good, but I've noticed the A/C causes the RPMs to drop a noticeable amount. The surging/bucking has been going on for a while now (usually only when I floor it and am at very low RPMs in 4-5th gear). Now it seems like it is getting worse.
High RPMs have no issue even with full throttle in any gear.
Very cold starts are accompanied by low (400-500 rpm) for a few seconds, then go away.
Randomly, when I start off in 1st from a stop, it will bog down when I try to give it gas and release the clutch. Yesterday it bogged down so bad, I tried to give it throttle and it stalled the engine before I could even begin rolling.
Replaced:
Fuel pump - 3 years ago - bought from Pelican Parts
Fuel filter - same time as pump, with new fuel lines
DISA valve - 3 years ago
New intake - 3 years ago (had a suspected vacuum leak)
1 new coil pack - 1 year ago - had a misfire cylinder 1
Spark Plugs - 1 year ago - NGK laser iridium, I think
Possible issues?
I keep reverting back to VANOS thinking this fits the description pretty well. But with no CEL, it's difficult to narrow it down.
I'm also considering the fuel pump, idle air control valve, A/C compressor, A/C pressure sensor, coil packs, vacuum leak... the list only goes on. :tsk:
I'd appreciate any insight you guys might have. I'm planning on taking my car to my buddies shop to have him do a fuel pressure test and check the A/C system pressure just out of curiosity.
Car:
2004 325CI Coupe
M54 Engine
5-speed manual
203,000 miles
Problem:
Replaced:
Possible issues?
