Hey guys, I have a possibly unique situation going on. If you look at my previous posts, you can see that this car has been a project for a while. It is in a much better state than when I first got it. It starts, runs, and shifts smoothly for the most part. Aside from a couple of random codes that get thrown at me, this car always had a rough idle since I got it. There were a multitude of issues that needed to be attended to first before I tackled that, i.e. alternator, transmission valve body, rewiring fuse box, fuel pump, ABS/DSC, etc. The car had water damage.
I drove the car up and down the road for a bit, approx. 10 miles, and the transmission jumped into limp mode and SES light went on. Strangely, it didn't stay on 3rd or 4th gear. It ran like normal, just shifted a bit more aggressively. I was just getting home anyways so I checked out the codes and I have:
Here are a list of things that I have already checked out: DISA (seal and the unit itself), cam intake sensor, MAF sensor, intake gasket, intake smoke test, ICV and continuity between the lines and the control units. I am leaning towards this being a VANOS issue. I remember reading that these positions that the VANOS is stuck at is the failsafe position. In terms of the codes listed above, do you guys think I missed something? What do you think this issue can be? Thank you ahead of time for any input or advice!
- P0011 28B6 value above threshold
- 3C1E implausible value
- 28A2 value above threshold
- VANOS intake stuck at ~126 degrees and exhaust at ~-101 degrees
- 145 and 146 transmission codes
