hello there..i got e46 325i
I'm having a problem : vanos exhaust side end position not reached. when i scan using bmw scanner 1.4
I thought because of the bad O ring vanos then I decided to buy a vanos O ring kit and do the vanos job. then i did a reset timing by a bmw specialist repair shop at my location. Previously I also found that my exhaust vanos oil gate was stuck and I cleaned it when I tested it can move freely again. the first time I disassembled the vanos there was no oil pressure in the exhaust vanos but after I cleaned the oilgate and I disassembled the vanos for the 2nd time there was oil pressure in the exhaust vanos.
but now i'm still having this problem. Can this be caused by a labored ex cam sensor? I'm stuck with this problem
sorry for my bad english
thanks in advance
thanks in advance
