1 - 20 of 35 Posts
2002 BMW 325I with 175k miles
I'm sure there are a ton of these in here, but I felt like I did the valve cover gasket really well. I tightened them down well, got a new/used valve cover itself from an XI that had around 70-80k miles on it. And even used some RTV. But it's leaking from the back left and onto the sensor that's attached to the top of the manifold. Should I take it off and just put some RTV in that area?
2005 BMW 330i
What brand gasket
The left side cover sit higher than the right side which all the oil pooled on this side; I don't see why the leak is on higher side instead of lower side. What sensor attached to the top of intake?
where did you add the RTV, and how thick?
Last week I removed the VC off my 2003 525iT to investigate a small leak at front right (on top of EX cam sensor); a drop or two on ground every trip. Turned out the PO added too much RTV on the area and all the half-moon pieces causing uneven sealing surface. I removed and cleaned all, reused the old gasket and added a thin RTV, on the head and not the gasket, at the half-moon pieces and the 2 seams where vanos contacts the head. Leak free now.
Discussion Starter #4
Interesting, I took a microfiber cloth with brake fluid and cleaned off the surface and I only put a small dab of RTV at the Semi Circles.
E46 '04 330Ci convertible 760 K km
Elring gasket with new screws and washers and gaskets for the screws
Even low quality gasket, if new, will seal cover properly, it jsut won't last. Elring is good one.
If you replaced gasket AND all rubber grommets with new ones, and applied tiny amount of silicon sealer on corners of VANOS, then it shouldn't leak at all. Tighting nuts more won't change anything. It is possible that your cover has cracks. You probably should remove it again, clean everything and inspect closely. Do not use RTV anywhere else but those VANOS corners and on lines where timing belt cover mates head (as on that pic from google, just apply less amount)
919214
1) I think you forgot the rear 2 half-moon areas on the head -- just same as on the vanos.
2) One important point is don't wait too long or the RTV got firm then the gasket cannot flatten the glue, causing uneven gaps and leak. The reason to add RTV only to the metal surfaces and not to the gasket is easier to control how thin the added RTV.
This picture is an example of adding too much RTV and will cause gaps and leak.
I did forget, in fact.
And, as mentioned, as tiny amount as possible, excess won't help at all but can end up travelling inside engine.
Discussion Starter #10
So put less RTV then on those pictures, and put them on the back of the valve cover too? Got it!
Curious as to why you needed to replace the VC itself.
Insofar as brands of gasket: Dealer, Elring.
For those that don't do this sort of thing everyday like I do, carefully move the O2 wires and SAP vacuum hose so they can't get in between. Lay the cover on the head and then take an inspection mirror and light and spend a minute (really a minute) looking around the back and the half moons. Look 110%? Press on.
Valve covers in general for the E46 are robust, could be a hairline crack. My money is on an old hardened piece of gasket.
Discussion Starter #14
I replaced the original because it had 179k miles on it and I just assumed it would be warped. And the gasket is brand new, I don't think it's a hard piece. But before it definitely was, couldn't even get it off with putting a knife/screwdriver to the old gasket.
E46 F10 W204 W212
Make sure you didn't pinch the oxygen sensor wire on install. It's happened to a few here.
2006 330ci zhp
Are you saying left side as you are looking at the engine? The manifold is the exhaust manifold and the sensor is the O2 sensor? It does make more sense the valve cover would leak back there. That's where oil would sit.
Discussion Starter #20
919275
Leaking right here onto this sensor. Probably O2
1 - 20 of 35 Posts
