1 - 20 of 25 Posts
UUC claims to work perfect with factory or any suitable shocks. Just want to lower car a bit and slightly better handling. Anybody choose between the two?
I ordered some UUC's, but I haven't received them yet. I ordered them because they claim that they are a perfect match with the stock shocks and I have heard only good things about them from other memebers.
Banned
I got the HR race because i like the way it lowered my car. and for the shocks, they'll wear out sooner or later, so replace them with some aftermarket ones. also i dont really see how UUC are better than HR (refering to shocks) because both will have the shocks compressed already becuase the springs are shorter. i know that UUC says they have "progressive rates" but the spring is still shorter.
From what I understand, the spring rate is the same, or close to the stock spring rate. I heard that someone had the v.1 springs and put over 30k miles on them with the stock shocks with no problems. I don't know of anyone who has gone that long with other brand springs and having the stock shocks last that long.
Discussion Starter · #7 ·
I have the non-sport suspension. My shocks are about due for replacement. Shocks don't last too long on New Orleans pothole laced streets. I figured I'd replace shocks with aftermarkets and take the opportunity to lower them car a bit to match the 17 in RIMS. Don't want to go racing low due to the potholes down here.
anyone got pictures of UUC V2 springs on a sedan with stock non-sp shocks? thanks. kinda want to see the side shot of it and see how much does it lower compare to stock non-sp suspension. thanks.
don
BGReddy00 said:
how the heck are you gonna be able to drive that brandon once you get the wheels?
19's raise the car
1st FULL '02 ACS 330i
p0tpie said:
19's raise the car
True. In my case...
I'm going to be running 245/35/19 in the rear...that's +1.98 cm larger diameter in the rear (the gap will be even tighter in the rear by half of that....aprox. 1 cm smaller).
And I'll be running 235/35/19 in the front...that's +1.28 cm larger diameter in the front (the gap will be reduced by half of 1.28 cm....aprox. 0.64 cm smaller).
The world of a difference that the 19's make with the appropriate tire is that it reduces the gap even more. So stock 17's aren't a good way to judge the final appearance of the UUC v.2's.
Front and rear will be higher by half of the diameter change. So the rear will be about 1 cm higher and the front will be 0.64 cm higher. My nose will be on more of an aggressive slant. With the added height in the front...Can we say COILOVERS!!!!
O'BlueTouring said:
thanks Brandon.. was your car equipped with sports package suspensions or non-sports suspensions? thanks.
Don
I had a sports suspension. The OEM sport struts/ non-sport struts won't make a difference on your ride height...unless they are bottomed out and can't go any lower. but I couldn't ever see that happening (except while driving over some pot holes).
Discussion Starter · #17 ·
I think I may go with UUC then.
I have the non-sport suspension. I'm about ready to replace my shocks so I figured I would lower em a bit to give a more aggressive profile on the car. But you know about the pot holes down here in New Orleans. I don't want to drop too low and have a proble with a flash flood in spring. :)
hamann330ci said:
If I was gonna lower my car, I would go w/ the UUC. It claims that it works w/ the stock shocks. You got sport or non-sport suspension? And how come I don't see your car around?
jun14scr said:
brandon you just have the regular set up, not the mixed, right?
That's right. It's the standard setup. The rear will look really tucked when I put a 245/35/19 on there in a month or so with my IForged Senekas.
BTW...the springs settled a bit more since those pics and I found that the ride got a little smoother. Maybe it's in my head.
Mixed setup = V.2
Guys UUC is telling me the V.2 is the mixed setup. Its one in the same thing. They don't have 2 different V.2 springs. They only make one set of springs in the V.2.
1 - 20 of 25 Posts
