teamdfl said:
| What he said
Convention dictates that the printing should be right side up on a spring when installed properly.
yeah...the spring install is a piece of cake....it's just that i forgot about whether it goes in one way or another in the rear....buti think i found the answer from the DIY files......in the pictures you can see the tighter wound coils are at the top which is what i did.....
<img src="http://performanceix.com/howto/images/12/35.jpg"><img src="http://performanceix.com/howto/images/12/41.jpg">
i like the uuc springs...the ride is not much worse than stock...my only complaint is that there seems to be a little more gap in the front than in the back....that's probably b/c i have 18's this year instead of the 19's i had last year so it's more noticable.....as far as the lettering being up or down, i called UUC last year about this and they told me it didnt' make a difference as long as the spring is put in properly.......b/c when i put the springs in, it fit when the lettering was upside down....but all in all, i'm happy with them
