1 - 10 of 10 Posts
my friend put the wrong coolant in her car :banghead: . Will it be a problem if I sucked it all out then added the right coolant?:dunno:
frequent tire purchaser
If you flush the system and put in the correct coolant, you shouldn't have a problem.
Network Analyst
Johns said:
what if I just put a tube in the coolant tank and suck it out. is that a bad idea?
:confused:
Just use the drain valve, man. It should be on the radiator near the bottom of it if I'm not mistaken.
dave
Discussion Starter #7
forget about my question above. found problem..
the right coolant is the blue color from bmw. u can only pick them up at the bmw service.
Discussion Starter #9
is it a problem to mix a coolant.. Say I had the wrong coolant in my car and it was low, then I topped it off with BMW coolant. is that OK?
neck said:
people always say to use the bmw stuff.
i've topped off w/ prestone cuz i dun feel like it matters.
30K+ gamble... I'll stick to using the "correct" coolant... If you compare the ingredients in the Prestone to the BMW coolant, you will see that they are different... will this matter? I guess YOU'LL find out! :eek:
1 - 10 of 10 Posts
