1 - 10 of 10 Posts
I'm looking to upgrade my regular phone to bluetooth.
What are the parts I need.
I allready got the BLUETOOTH ULF Module.
And offcourse microphone, and steeringwheel control.
I got the 16:9 navigation system MK4.
Help would be appreciated,
MXL
Not sure what we are talking about here? Do you have a bluetooth cell phone? If you don't, that is what you need. The microphone should be there already (it is in the US I think)
Banned
I think he is talking about the phone system for his car. If thats the case here is a link to our Bluetooth kit for your car:
http://www.bavariansoundwerks.com/product.php/II=497/_cid=305
This kit allows you to use all of your factory settings, your steering wheel controls for the phone and everything. Let me know if you have any questions!
Discussion Starter #6
I guess i need these parts:
- Original BMW Wiring Harness (included and/or modified as required by vehicle model)
- Original BMW Bluetooth Antenna
- Original BMW Fakra Cable
- Original BMW Owner's manual set w/ Installation Supplement as required
- Original BMW Pairing Button / Harness for center console
- Original BMW SES Jumper Plug (as required)
Anyone know where to get these?
european auto source
MXL
Since you are based in the Netherlands - more than likely the prewiring isn't there if the vehicle was not originally ordered with a phone. Remove the cupholders and check to see if you have a 12-pin plug present. All US e46 models were prewired with phone connections.
The most important piece is the ULF module. Do not run nothing less than a 5th Generation module in your e46, and the latest generation if possible. If you are unsure of the ULF generation, ask for the part number. We have no problem telling you, and have all 10 Generations listed on our website.
More information on the kits can be found on our website:
BMW Bluetooth Retrofit Kit for e46 3-series
http://www.europeanautosource.com/product_info.php?cPath=67_153_156&products_id=299
Feel free to respond with any questions you have or contact me directly.
There already is a phone in the car OEM, working with navi.
I want to upgrade to bluetooth.
So i think the car is wired.
You will need:
P/N 84 11 0 302 639 - Bluetooth Installation Kit
P/N 84 11 0 018 038 - Voice Input System Jumper Plug
http://golilm.com/DIY/Bluetooth/3SeriesInstallation Bluetooth.pdf
Those two part numbers contain everything that you will need to connect your ULF to the existing Phone prewire in your car.
Your local dealer has those two parts... good luck. :hi:
1 - 10 of 10 Posts
