1 - 4 of 4 Posts
2004 325ci
Hello there. I have tried looking a ton about this item and just want to know what it is and what it does. The black box with 5 brown wires coming out of it. This is on the same harness for the headlights. Thank you.
Automotive tire Motor vehicle Grey Wood Twig
2000 320Ci 2.2 vert MT
you can fit "everywhere" you have something to bolt on chassis, they all are brown wires=grounds. If you look at the bolt emerging from the chassis on the upper right of the pic, you can bolt it there with a nut. there may be a similar one near the headlight.
in extrema ratio if you can't find some other bolts you can reach from there, you could screw one in the chassis everywhere :)
2004 325ci
Discussion Starter · #4 ·
Awesome thanks. I am actually back tracing all these wires and running them inside that little channel where the fender meets up to wire tuck them. This means I can cut that and just ground all of those up further by the fuse box.
1 - 4 of 4 Posts
