1 - 10 of 10 Posts
Hi, all. Sharing my '03 Z4 3.0i (E46 roadster ;) ) bottom-mount turbo build.
Brief overview:
-MS43 ECU
-Has air conditioning
-CX racing GT35R journal bearing turbo
-E83 X3 2.0d Luk clutch disc, N62 Luk pressure plate, stock Luk DMF
-M50 intake manifold and fuel rail (return is welded up)
-Bosch 0280158123 630cc injectors
-B6 Audi S4 MAF sensor
-Precision turbo PW46 46mm wastegate
-EMUSA Intercooler 25in. (total length; core length is 18in.) x 12 x 3 (2.75in. core)
Turbo Specs (CX racing GT35R journal bearing)
***8226; Compressor housing - .70 A/R
***8226; Turbine housing - .63 A/R
***8226; Compressor Wheel 61.3 /82 mm
***8226; Turbine Wheel 62 /67.8 mm
***8226; 4in. inlet and 2.5in outlet
https://www.youtube.com/watch?v=FLfUtnFQEuw
Link to my wheelwell page with tons more photos and info:
https://wheelwell.com/vlad-belsky/2rj3/2003-bmw-z4
Discussion Starter #2 (Edited)
List of items purchased and costs for the build
Turbo Oil/Coolant feed
***8226; Rally Road Feed line (bottom mount)- $33
***8226; Rally Road Vanos bolt adapter to AN4 line- $33
***8226; M14x1.5 to 3/8 barb (coolant to block)- $9
***8226; 1/8 npt to 3/8 barb (coolant to lower rad hose)- $5
***8226; 36 mm coupler with 1/8npt hole- $10
***8226; Drain line (5/8 in pushlock hose and 3/4in heat shielding)- $20
***8226; 5/8in weld-on aluminum bung for oil drain- $5
***8226; Oil pan baffle kit and oil pan gasket- $204
***8226; 10ft 3/8in ID ss braided teflon line- $40
Clutch
***8226; E83 X3 2.0d Luk clutch disc (part # 21207553770)
E60 550i pressure plate (from Luk kit with BMW part # 21207573789) - $340
***8226; Clutch alignment tool - $8
***8226; Pivot pin brass - $18
***8226; OE Luk flywheel (part # 21207533868) - $370
***8226; New flywheel bolts (part # 11227519572) - $46
Intercooler
***8226; 2.5in Pipe kit $72
***8226; Intercooler $80
***8226; Intercooler mounting materials - $20
***8226; Extra 2.5in 90 elbow - $9
Fuel System
***8226; Bosch 0280158123 630cc injectors - $250
***8226; Injector spacers - $40
***8226; Used B6 Audi S4 Bosch 1800kg/hr MAF - $35
***8226; Deatschworks DW200 255lph fuel pump- $86
Exhaust
***8226; Manifold ($140 including labor to machine it)
***8226; VHT 2000F paint- $20
***8226; Dump tube and downpipe starter fab + material - $140
***8226; T304 stainless 3in V band clamps/flanges x 3 - $54
***8226; 8FT 304 stainless 3in pipe - $60
Turbo
***8226; Turbo - $300
***8226; Rally road E46 turbo engine mount arm w FEBI 15786/274111 engine mount -$180
***8226; Precision Turbo PW46 46mm Wastegate - $350
***8226; TiAL-style (Tial BV50 replica) 50mm Blow Off Valve - $54
***8226;-11lb spring for BOV - $15
***8226;Genuine Tial O ring for BOV - $5
Air Intake for Turbo
***8226; 4 in to 2.5 in 45 degree elbow/coupler - $10
***8226; 2.5in inlet cone filter - $14
Gaskets/Misc
***8226; Exhaust manifold gaskets (BMW part #11621728984)- $18
***8226; Copper spray Permatex 80697 - $10
***8226; M7 exhaust nuts part #11721437202- $10
***8226; Engine/trans mounts - $45
***8226; Spark plugs NGK BKR7E (set of 6) - $18
AEM Failsafe 30-4900 wideband/boost gauge- $300
Fabrication costs
***8226; Oil pan modification labor- $100
***8226; Fabrication labor for exhaust, charge piping, and air intake- $650
Total:
$4226 USD
Discussion Starter #3
Aaaaand gonna grab this box for videos/additional photos/links
Could you PM me a link to that exhaust manifold? Looks a bit better than a lot of the other log style ones I've seen
Edit: Nevermind, I found it on eBay, lol. However, I do have another question. I have a bottom mount turbo 330Ci and currently my charge piping interferes with the front subframe crossmember. How did you do your turbo-to-intercooler charge piping? Did you use a silicone elbow from the turbo? If so, any issues due to proximity with the exhaust manifold? I found a shop that would be willing to weld a metal elbow onto the turbo itself, but if I decided to swap turbos (which I very well might this spring), then I'd have to have it re-fabbed. Any insight is appreciated, thanks!
When Keepin' it real goes..
Beautiful build!!
Discussion Starter #10 (Edited)
...How did you do your turbo-to-intercooler charge piping? Did you use a silicone elbow from the turbo? If so, any issues due to proximity with the exhaust manifold? I found a shop that would be willing to weld a metal elbow onto the turbo itself, but if I decided to swap turbos (which I very well might this spring), then I'd have to have it re-fabbed. Any insight is appreciated, thanks!
I added a link to the original post that has some photos that will help you!
Also updated the post with a youtube video!
Beautiful build!!
Thank you :D
1 - 10 of 10 Posts
