trunk handle fix
6 reading
4.2K views 16 replies 9 participants last post by  sergio
#1 ·
Here's How I fixed my trunk handle with out buying a new Peice from the dealer ship
DIY price $5.00 Labor 1.5 hr
first you will need to Buy fast set epoxy, for plastic and metal, and get four washers or however many you need.
Tools used: torx socket, solder gun (recomended) , 3/16-1/4 drill bit depends on the size of the opening on the washer you intend to use, a popsicle stick for appling the epoxy, some blue tape and an exacto blade, and needle nose plyer.
Step one: Lossen and remove all Four Bolts
Second Step: place some kind of paper towel or old rag on the bumper to avoid and glue falling on th paint.
Third step: Place some tape around the hole, so the glue doesn't get on the foam padding
Fourth step: place your washer inside the housing, try to line it up in the center
fifth step: Using a solder gun, I placed it against the washer using a little pressure to heat up the plastic, allowing the plastic to melt and seet the washer. By doing this the washer can't move when applying the epoxy. I suppose super glue can work to, haven't tried it.
After I melted the plastic
Sixth step: Before applying the epoxy, roll up some paper to plug the washer hole. I only filled one hole at a time, because of the epoxy drying so fast. Apply the epoxy slowly until you reach level with the foam padding.
should look simialr to this
seventh step: Remove the tape, I used an exacto blade and needle nose plyers to remove it, sorry no picture. Then use a drill and drill out the paper rolled up in the center. Drill from the repaired side, so you don't scratch the paint.
Eighth step: Install, Tighten the bolts down evenly until totally snugged up. If the holes don't line up all the way. use a smaller drill bit and longate the hole to the right spot.
I saved allot of money, and its even stronger Now. Good luck
#3 ·
i dont really understand what you did. what was the problem?
#4 ·
this is what the factory part looks like before it breaks
Three out of four broke, do to someone trying to pull up on the handle, without pressing the button supplied under the handle. This is a picture of what it looks like broken
Hope I was more clear on my problem and the fix. Thanks
#6 ·
Three out of four broke, do to someone trying to pull up on the handle, without pressing the button supplied under the handle. This is a picture of what it looks like broken.
I think if you reduce the size of the pictures we may have a better look at what is wrong. I am too lazy to scroll over.
#7 ·
Bravo!! nice DIY, Mine is a 2002 325Ci and its only being held on with one screw now... (damn extended warranty doesnt cover trim peices i guess)
I was just about to fork over $105 for a new one from the dealer and swap it out myself (unpainted, it was $200 something painted)..I thought I'd check out the e46 forums.. and boy am i glad i did... Now i'm gonna get some washers and epoxy and give this a try tonight..
:clap:
#10 ·
Well I have to say mine is still holding up fine.. It feels solid still when i open the trunk. I did this fix on Nov30th so it's only been about 2 months but so far no problems. I was also worried about the epoxy, because it was like 30 degrees in my garage when doing it the epoxy was not the easiest to work with and I wasnt sure how well it would hold since i probably wasnt using it at the correct temperature, but no complaints so far.. saved me like $300 for the price of a new one painted..
#11 ·
I tried salvaging my old one by epoxying some new washers in... me and glue don't mix and it didn't even hold up for one day.
Bought a new handle from the dealership for around $90.00
Then I was able to seperate the original painted cover from the old handle... it is glued so you have to very carefully use a heat gun to pry it off... then I placed it on the new handle... that saved me from having to pay to get it painted & it turned out great!!!
I guess the problem with the handles breaking is that you have to wait for the electronic latch to disengage before yanking up on the handle which takes a split second. If you just pull up on the handle, you are putting alot of pressure before it releases. Just touch the pad and wait to hear the release, then pull up.
#16 ·
I was about to buy another trim piece but then I messed around with it and got my button working. So I decided to try and glue the washer back in. It's better than my first try and seems to be more solid. The handle is not sitting straight though. Most people can't tell, but I can.
