1 - 3 of 3 Posts
SBBMotorwerks
I just got a box with two 10s for my trunk. I want to clean up the install with a faceplate. But i have a few questions...
1. Do the subs attach to the faceplate (put the box in the trunk, then put on the faceplate, and then put in the subs and screw them through both the faceplate and the box)? OR
2. Are the subs attached to the box and the faceplate just goes over top of that (the subs are screwed into the box and the faceplate is attached to the fron of the box)?
3. How is a faceplate attached in the trunk?
I am trying to come up with a set up that will look really clean but will be fairly easy to remove if i need the additional trunk space.
Obey my dog
by faceplate you mean like this?
my car audio shop always called it a flush panel but i guess faceplate works too :) (unless you are talking about something completely different). my subs are attached through the faceplate into the box and this is what holds it in place in the trunk.
1 - 3 of 3 Posts
