1 - 6 of 6 Posts
Ok so when I bought the car I found what seems to be the trans range selector switch just sitting on floor of passenger seat. The car runs and drives fine. ( well now it does after extensive amounts of work on it) but my question is does the car NEED this Installed? O
Premium Member
Year, model, transmission? Pic of part in question?
Premium Member
Thanks. Now I'm really confused.
When installed on the transmission and properly adjusted it communicates with the EGS.
You state it's running fine.
I would have to believe that the trans light is on and you have transmission limp home:
Reverse and Forward in 4th gear only?
Discussion Starter · #6 ·
I don’t have trans light on. Runs through gears fine. Not in limp mode . So I’m stuck trying to figure if I even need it or not .i don’t even see a place where it would connect to.. also this is random but would u know if there’s a certain orientation for installing center support bearing? Thanks
1 - 6 of 6 Posts
