Hello everyone, I have had my 2003 325ci for about five years now. Was told my transmission is done and needs to be rebuilt. I have some trouble believing this and I wonder if replacing TCU would work. Please read on...
About 2-3 years ago, I started experiencing the transmission limp mode. However, I found that simply turning the engine off/on again would do the trick and would last for about 1-3 months before going into limp mode again. At the time, I had a myriad of electrical issues and pretty much dismissed this as yet another annoying thing I'd have to eventually attend to. This continued until this past November.
Last November, my clever little trick stopped working and I could not get it to reset. So, I simply went to my regular mechanic and had him wipe codes (like I said, I've had so many other electrical issues in the past so I foolishly dismissed them). Also, just in case, I had a standard transmission tune up and replaced the fluid. Got the car back and she ran perfectly for another month and a half.
A few weeks ago, it went back into limp mode and wouldn't reset. This time, I brought it to a transmission shop. He ran the codes and basically said that it could completely break down at any moment. He advised me to not reset the codes and that the transmission absolutely should be in limp mode to be safe. He said it would need to be rebuilt for about $3600, which is of course very hard for me to swallow. I don't know the exact codes in number format but the three had to do with:
-Torque converter
-Misfire on Cyl 3
-Overheat
However, once again--perhaps I'm being very stubborn--I have a little bit of trouble believing that it is truly a mechanical issue. If those codes are legit, would I really have been able to continue to consistently drive it problem-free for years after?? Why did that tranny tune-up in November work for 1.5 months after?
I was wondering if I should try replacing the TCU. Could this be a possible solution? Or is my transmission really done?
-Torque converter
-Misfire on Cyl 3
-Overheat
