Related. That fuse is for the EGS, among others. You have a shorted oxygen sensor that’s causing it to blow, which is on that same circuit.View attachment 915624 Also the fourth fuse is blown. I don’t know if that has any relevance to this situation
I got new upstream oxygen sensors, and I’ll replace the blown fuse first thing in the morning. I’ve been looking to see what that fuse was linked to. Good thing you came along and told me. lolRelated. That fuse is for the EGS, among others. You have a shorted oxygen sensor that’s causing it to blow, which is on that same circuit.
I also have a valve cover leak. Do you think that possibly the hot oil dripped onto the o2 sensors and shorted them ??Related. That fuse is for the EGS, among others. You have a shorted oxygen sensor that’s causing it to blow, which is on that same circuit.
No. Those sensors are tightly sealed. Oil is not a conductor of electricity.I also have a valve cover leak. Do you think that possibly the hot oil dripped onto the o2 sensors and shorted them ??
In some cases, the wire routing of the wires are disturbed by previous repairs and melts or chaffes where it rounds behind the engine, so check that.I also have a valve cover leak. Do you think that possibly the hot oil dripped onto the o2 sensors and shorted them ??
Well I replaced the blown fuse and now the car won’t start 😐 it cranks but doesn’t startIn some cases, the wire routing of the wires are disturbed by previous repairs and melts or chaffes where it rounds behind the engine, so check that.
On replacing sensors, if you have spare fuses I like to test and find out which one of the sensors failed by disconnecting them one by one until the fuse no longer burned out on position 2. No need to start the engine. In fact I would have done this first, in case the problem was the post cat O2s.
and there’s an odd ticking / noise coming from the fuse carrier nowIn some cases, the wire routing of the wires are disturbed by previous repairs and melts or chaffes where it rounds behind the engine, so check that.
You sure you connected everything back correctly?Well I replaced the blown fuse and now the car won’t start 😐 it cranks but doesn’t start
Im positive I did. I don’t know what could be going wrongYou sure you connected everything back correctly?
No it just wouldn’t start. It would start cranking but it wouldn’t actually start. Before I replaced the fuse it started right up no problemAny chance this car was started, moved a couple feet and immediately shut off?
Let me ask a different way. Did you ever start this car for a few seconds then turned it off immediately? Because it sounds like washed down cylinders.No it just wouldn’t start. It would start cranking but it wouldn’t actually start. Before I replaced the fuse it started right up no problem
No this is the first time it hasn’t started on meLet me ask a different way. Did you ever start this car for a few seconds then turned it off immediately? Because it sounds like washed down cylinders.
not sure. I didn’t wanna look again and get disappointed lolIs the fuse blown again?
Fourth from left or right? Remember no body can read your mind.View attachment 915624 Also the fourth fuse is blown. I don’t know if that has any relevance to this situation
Well, then reverse of what you did to the point that it started ok before. We can walk backward can we?Well I replaced the blown fuse and now the car won’t start 😐 it cranks but doesn’t start
