1 - 3 of 3 Posts
There are numbers going around the handle starting from 0. On the shaft there are the levels of pounds/ft going up. How do i set this? I know if i twist the handle up the torque increases, but what are the numbers going around the handle for?
Bimmerfest Co-Founder
The numbers going around the handle are the increments between the numbers going up the shaft. For example if on the shaft there is a line at 10 and at 20 then around the handle it should have 0-9 so if you start at 10 ft/lbs and need 15ft/lbs you turn the handle until the 5 lines up with the center shaft line. That gives you the 10 plus 5 = 15. Look at it, turn the handle, think about it and you should be able to figure it out.
Tim
1 - 3 of 3 Posts
