Bought it with the top issue.top was closed, found out the front latch motor was broken, replaced it, now it works, but not like it should. Opens fine even though a bit slower then it should. When its time to close the rear lid opens like it should the top starts to move very slow. If i keep my finger pressed sometimes it will raise and close but it will take minutes and minutes, most of the time the motor will keep running but the top stays where its at, anout 10 inches above its resting point, then if i help it a bit it will rise, again slowly, but that is the heaviest point inits rise, is the i itial part. Fluid in the trunk motor is full. Possible the motor in the back is just weak? I have had several of these in the past but none were this slow, and either working or not. Is there a way to attach a video here?
