After i changed my soft top canvas some weeks ago I topped my pump reservoir.
Was quite low but already on the "spot", an acceptable leak/loss after 4 years.
When I changed the top I inspected for what was in my little knowledge of there were stains/marks of oil around the soft top asembly. No visible signs, no stains or similar. I always had the insulating sponge wrapping the pump "oily", but not more than my ex z3 for example: something that seems trasudation.
After soft top was correctly reinstalled, I enjoyed it and opened/closed 10/12 times approximately: I retested today the level 'cause I felt the soft top a little "sluggish" on closing with car on a downhill and was quite low again. Again near the lower part of the "spot" on the reservoir.
I've searched the sticky link but are (obviously) for repairs, can someone suggest me where to start finding a leak, weakest points ecc? Some suggestion to find very slow leaks/methods?
Due to the fact that the pump assembly is a little "oily" I was wondering if cleaning it with breake cleaner or similar maybe I will notice on next weeks some specific points of leak. Is it safe to clean with that kind of aggressive cleaners? I don't know honestly if it'll help, cause I think the leak will be microscopic to see at every lift/storage of the soft top.
Advices on your experiences? On post #5 I've found the pump may be leaking somewhere.
- True I moved the top for 2 weeks by hand when I changed the soft top
- true the pump has surely some trasudation: is always a little "oily", but there are no visible signs of stains or losses in a particular point.
- The system itself has "pressure": if I leave the soft top open half way, there's no way to move it by hand before some minutes necessary for the system to "unpressurize" leaving it there
- while opening/closing the soft top several times changing the canvas, I left the soft top halfway witht the system pressurized. When it de-pressurized I heard a loud "sound", a "whistle" of the system losing pressure after some minutes. Never heard it before, and was not the first time I left the soft top halfway
