I can't figure out how to log in torque for some reason, I set the PID to capture data and then email a csv file but the data doesn't look right, I'll play with it more tomorrow. I watched the timing under full throttle and only saw around 23 degrees advance and when coasting it works its way down to around 5-7. Not sure about the TB and its relation to engine load, thought the idle was controlled by IAC. I should also mention that I have no O2 sensors hooked up yet, still waiting for the exhaust to be done. Not sure if that has anything to do with it, I obviously have codes for the O2 sensors but I'm seeing a misfire on cyl 3 so I'm gonna swap the ignition coil tomorrow after work and see what that does. Another thing happened tonight, engine stalled on me, started right up and didn't do it again so I'll attribute that to gremlins for now until it happens again! Once again jfoj, I appreciate your time and expertise. I'll report back soon as I can.
