1 - 3 of 3 Posts
Hey I've been to both the websites and it seems from searching on the forums that both sways are well liked. It looks like the Ground Controls are a little thicker in in its "effective diameter". Are both easily adjustable? Is one more prone to oversteer if it is too stiff? Let me know any experiences with either. Also does the ride suffer from either? Thank you for ANY input.
Mom says I'm a catch
research about the Eibach anti-roll kit. That's what I have in my '00 323 and I love it but then again I can't say if it's better or worse than those other 2.
Adjustability shouldn't be that tough but it could take awhile so when you install them, set it on the furthermost to the outside hole, softer setting; and then drive around so you can get a feel if you want to make it stiffer or not.
good luck
Alex
1 - 3 of 3 Posts
