Ho ho ho bimmerheads. Merrily having myself some festive wrenching here. With the engine rebuild near enough finished, I'm now just tying up all the other loose ends to hopefully drop it in before the end of the year.
First off, got a nice wee letter from
@yjsaabman in the mail the other day with a manual cluster backing plate thingy. Absolute legend, made me feel all warm and fuzzy inside. Thanks mate!
Had a bit of a dilemma with the power steering situation. The donor car came with an LF-30 pump that I had already pulled apart, cleaned up and refreshed with all new seals. Was prepared to bite the bullet and get a new high pressure hose from BMW for something like NZ$400+ as those are different between the LF-20 and LF-30. Got a quote from BMW a few weeks prior and was told it's available on order from within the country. Gave them a call to get one in and was instead told it'd need to be ordered from Malaysia and would be unlikely to arrive until sometime in January at the earliest.
Looked over the current LF-20 hoses and they're actually in decent enough nick, problem is the LF-20 pump itself seemed to
have some play in the shaft making an audible rattle, which left me a bit uneasy. Ended up going for another scavenger hunt to Pick-A-Part, hoping to either find a pressure hose for an LF-30 or a decent enough LF-20. Out of the 7 E46's there, the LF-20's had either been taken or they'd come with LF-30's so I ended up grabbing a pressure hose for the latter for just $16... then took it to a hydraulic shop and dropped $300 to get it refurbished. Smort.
The steering rack itself seems in decent nick and I found this engraved in it when wiping it down.
It seems to say "03.15 209k" so wondering if it's been refurbished in March 2015, at 209k km? Bit weird as I bought the car at 214k km's in 2021 and it's unlikely it'd only done 5k km in the 6 years, so assume the rack must have come from some other car at some point. Anyway, tangent.
Tackled the wiring looms next. Did a thorough inspection and gave everything a clean, cleaned off a few oily connectors with some contact cleaner and replaced the bits of plastic corrugate sleeving in places where it had crumbled away it. Also removed the auto transmission / O2 sensor loom from the ECU/relay box and tidied up the reverse light wiring I'd left in a bit of a dodgy state previously. Properly crimped and heat shrunk everything in place and culled or tidily tucked away the remaining automatic transmission wiring bits going into the cabin. Also found some sort of... repair someone had taken on previously?
Bolted up the new dual mass flywheel and clutch kit and mated up the engine and gearbox. Finally found a good use for two old bean bags my partner's been nagging me to throw away for a good part of two years now. Make a good cushy bed for the engine to take some pressure off the crane.
There's two E14 bell housing bolts that are longer on a manual box than they are on an auto so I made sure to order those in (part no. 23001222894). Looking at it, the auto ones would probably do the job but wouldn't engage the threads fully so best to be safe.
Got pretty annoyed when I got onto bolting on the main tensioner and it started spewing oil all over the place. Frustrating as it's barely a few years old. Bought it from FCP Euro as well so would be covered by warranty but can't imagine the return shipping costs would make the exercise worthwhile. Also discovered that I'd bought the wrong type of AC tensioner so have ordered new ones of both, should be here beginning of the coming week.
Gave the exhaust manifolds a good scrub and will look to throw those on prior to the engine install. Not a fun task bolting those on in the car.
Gave the whole car and the engine bay a good clean, it'd done a great job collecting pollen, dust and bird shit these last few months. Getting really annoyed at the horrid state of the paint now. All going well with the mechanical side of things, I suspect a full respray is on the cards in the not too distant future.
Have rolled the car back into the garage finally, tidying up the last few bits and will start tackling the engine install.
Plan is still to get the car up and running, break the engine in properly, go for WoF and start tackling the other missions that will knock the wheel alignment out of whack. Front subframe will get all new control arms, bushes, wheel bearings and tie rods, whole rear subframe will be refurbished and will probably throw in adjustable camber arms for good measure. With the subframe out, also aiming to tick off the reinforcement plate mission. Got a full kit from
CMP as well as the weld in beam that goes along the back of the rear seats. Not sure if I'll end up going all the way with it but best to have it on hand anyway. Will also try out their solid steering coupling. Currently has a poly coupler that is a squeaky little piece of shit so definitely getting rid of that; more on it in a future post. 330 brakes are still waiting to be rebuilt. Some might have also noticed boxes of suspension bits on the shelf in one of the photos. Got a set of Eibach Pro Kit springs and Bilstein B4's all round on a decent deal. Big pile of plans there but should feel brand new when I'm done with her.
As far as more immediate tasks, will probably take the driveshaft to a shop to get tested/balanced. Paid extra to get the rear part of the driveshaft send over along with the manual conversion from the UK but the dude didn't mark it at all when removing so no idea how it's supposed to line up. Bit silly.
Also haven't quite settled on what to do with the exhaust. Lined the 325 & 330 ones side by side and apart from the flap at the tail pipe on the 330, they seem to be pretty much identical? Leaning towards going with the 325 one if so. Am also thinking I'd like a bit more volume out of it so keen to hear some suggestions as to the best course of action, short of dropping a few grand on a full new setup. Don't want it to be stupid loud but in stock form it seemed barely even noticeable so just after a slight increase. What sort of difference would cutting out the secondary cats / resonator make? I assume deleting the muffler is sure to make it obnoxiously stupid?
