Here's some to-do lists, if nothing else then just for myself to keep better track of everything.
ENGINE
ENGINE
- All new seals, O-rings, gaskets throughout (all Elring).
- New rod & main bearings (Glyco).
- M52TU-style piston rings.
- New timing chains (iwis), guides (Febi), upper tensioner (INA), new spring for main tensioner (Genuine).
- Slotted oil pump nut (Turner Motorsport).
- Rebuilt DISA with aluminium flap & replaced membrane (local vendor).
- Rebuild VANOS (Beisan Systems kit).
- Donor engine is older style but will be using the harmonic balancer (keep it compatible with the current AC system) and valve cover from the newer-style engine original to the car. As far as I can tell, those two things are the main difference between the two and should just be a straight swap?
- New crankshaft pulley bolt.
- New plastic coolant hoses to block & head (Rein, oops).
- New VANOS feeder line (Rein).
- Injectors professionally cleaned & tested.
- New ignition coils (Delphi) & spark plugs (NGK).
- New CCV & associated hoses (OE & Rein).
- New thermostat (Borg Warner). Water pump, radiator and radiator hoses I replaced last year.
- New intake boots (Febi).
- Replace all other vacuum hoses and vacuum caps.
- New engine mounts (Corteco).
- New crankshaft position sensor (VDO).
- New ignition knock sensor (VDO).
- New cam position sensors (VNE).
- New pre-cat O2 sensors (Bosch).
- Considering deleting post-cat O2 sensors altogether. As far as I can tell, they don't really do much in terms of engine operation itself and just monitor emissions. There's no emissions testing in NZ so figure I might save a couple hundred $ and just bypass altogether. Need to figure out how to code them out to avoid CEL.
- Clean up crusty gearbox with brass wire wheels / brushes.
- Replace all detents & shift pins. Have already got the new hardware and have ordered the special install punch kit.
- New shifter bushes and pins.
- Shorter E60 shift lever.
- ZHP gear knob.
- Metal clutch fork pivot pin.
- New clutch kit & double mass flywheel (LUK).
- New slave cylinder (Sachs).
- New backup light switch.
- Replace gearbox oil.
- New transmission mounts (Corteco).
- Install LF-30 pump that came with the donor car.
- Will need to source new pressure hoses / custom make new ones. RHD ones are stupidly expensive and hard to source with only overpriced genuine ones available from very few vendors.
- New PS reservoir (ZF) & hoses (Rein).
- Have two purple-tag steering racks to choose from, will need to compare condition and make the call.
- New tie rods & boots (Lemförder).
- Need to figure out what to do with steering coupling. Again, RHD variants generally don't have OE options available and are stupidly expensive. Considering replacing with poly / solid aftermarket alternatives as due to proximity to exhaust manifold, rubber tends to wear out quicker, despite coming with a protective metal "hat". Unsure whether solid coupling or similar might be a bit too harsh for a daily driver though, especially with shitty South Island New Zealand roads.
- Clean & paint rusty manual driveshaft.
- New flex joint / guibo (Meyle HD).
- New center support bearing (Rein).
- Clean & paint rear subframe & trailing arms.
- All new rear subframe bushes (Lemförder).
- RTAB limiters (Daystar).
- New rear wheel bearings (***).
- Will probably get a set of H&R sport springs.
- New front & rear coil spring rubber shims & pads.
- New Msport front front control arms (Lemförder).
- New lower profile E90xi strut mounts (Sachs) & strut mount reinforcement plates.
- Eventually replace rear Monroe shocks with Bilstein B6's to match the fronts.
- New rear shock mounts (Lemförder) & reinforcement plates.
- New rear sway bar links (Lemförder).
- New front & rear sway bar bushes (Rein).
- Clean & paint 330 brake calipers.
- Rebuild brake calipers with new seals.
- New brake hoses (either ATE or SS braided aftermarket, haven't decided yet).
- New brake pads (Akebono?).
- New park brake hardware and brake shoes (ATE).
- Wire in reverse light switch.
- Wire in clutch switch.
- Flash DME to 330 software & update to latest version.
- Code out EGS.
- Code out post-cat O2 sensors.
- Code cluster gas mileage from km/L to L/100km.
- Change temperature gauge buffer range.
- Similarly, code the speedo to show the correct speed without a buffer - cannot locate the thread atm.
- Source front black leather sports seats to replace alcantara. Have already installed leather door cards and have set of leather rear seats to go in, just need to figure out the fronts. Considering E53 X5 or other plug & play alternatives, whatever suitable I can find really.
- Swap out cluster display from km/L to L/100km & install silver cluster surrounds.
- Armrest delete - picked up a shorter console off a compact from Pick-A-Part with all the mounting hardware. Need to strip it back to bare plastic. Armrest will be in the way once the car is a manual.
- Eventually buy Dynavin HVAC relocation bracket to tidy up the cigarette lighter area.
- Another one for the future, but looking to remove and redo all the scratched up / peeling / bubbled up window tints all around.
- Paint is beyond saving in quite a few places. Will eventually go for a full dent removal and respray if I own the car long enough.
- Might have to get new front bumper prior to that - one of the side brackets is hanging on and bottom is pretty badly scratched and cracked in a few places.
- New fender liners and other plastic trim bits.
- Potentially delete roof racks if I find a tidy enough set of plugs for the holes in the roof rails. Seen some of the 3D printed ones kicking about round here but don't quite look right for me.
- Some of the window seals are starting to crack. Need to look into if it's even possible to replace some of them.
- Will likely be keeping the 325i exhaust without the silly flap altogether, but will have to source some sort of tidy solution for exhaust tips. It didn't come with any covers at all the the 330i ones are a) old and ugly and b) one is too short due to the flap and don't fit properly.
- A few electrical gremlins to iron out - electric mirrors not working on either side - electric controls, reverse tilting, folding function - nothing. Have checked fuses and tried a different mirror switch with no luck. Also no obvious defects in the ribbon connectors or wiring. Will try swapping mirrors over from the current daily 330 to see if that helps pinpoint the culprit.
- Rear wiper doesn't work. Likely culprit seems to be sheared black wire at the top of the tailgate. Have ordered a harness repair kit but seems a real mission having to rewire everything. One for the future.
- Have also discovered that the PO had for some inexplicable reason replaced the wiper lever with one off a sedan so it doesn't have the rear wiper function anyway (should also have a push function on tourings and compacts to activate rear wiper). Have tried installing the correct one I pulled from Pick-A-Part with no luck, probably due to the sheared wire, but have picked up a second one as well in case the first one was faulty.
- Install reverse camera. Got one that is integrated into the licence plate light off Aliexpress that was specifically claimed to be an E46 model but the casing is too bulky to fit in so will need to be cut back and properly sealed again. Hot glue to the rescue most likely.
- Potentially looking to get a RacingDiffs LSD conversion kit sometime down the line.
