1 - 2 of 2 Posts
Hello.
The RPM needle is off by about 700 rpm in my car. However it is still functioning. By functioning i mean the needle moves up and down with the revs of the engine.
I have ran the test 2 on the instrument cluster. The needle moved all the way from 700 to almost touching the MPG needs on the other end. It was way past 7000.
Is there a way i can move the needle to the correct position without replacing the whole cluster? thanks Picture of the instrument cluster with the engine off
Absolutely easy diy. Two torx screws to remove cluster and only a few torx to undo the cluster. Once apart just simply(carefully) remove needle and replace at "0". Done Shouldnt take more than 10 minutes :thumbsup:
1 - 2 of 2 Posts
