I searched pretty extensively on this subject... So About 5k miles ago I replaced my entire suspension... H and R cup kit with sport spring, control arms, tie rods, sway bar end links, strut and shock mounts and such... Not long ago, around the time it started to warm up in May my suspension started making a creaking/popping noise. I put the car up on jack stands to check if there was any play anywhere.. I found none. The noise happens at slow speeds and not necessarily going over bumps.
From what I researched it sounds like strut mounts. I haven't taken my struts off yet to really check the bearing inside the mount, but the mounts were replaced with everything else. If it is in fact the strut mounts what would cause the mount to fail after such a short period... I drive like a grandma lol
Its a 2005 330i btw
Its a 2005 330i btw
