1 - 2 of 2 Posts
· Registered
am wondering if the reason that there are so few people here with superchargers is attributed to the fact that like myself, they are not that mechanically inclined and quite honestly - are afraid of what's involved in maintaining it. While I can only speak for myself, the price is not the dissuading factor to not get a supercharger - as is more the challenge/fear that I do not have nearly enough mechanical skills to maintain it.
I am honest enough to say that I am relatively lost under the hood of my car and would not dare to make any minor changes - yet alone something as major as retrofitting the engine and adding a supercharger. My biggest fear is after I have paid someone to install it - the daily/monthly/yearly? maintenance that it would need.
For those of you that do have them, or do have experience with them - can you tell me what is involved with the maintenance of this unit? is it temperamental? Does it require constant tuning and tweaking?
TIA
Chris
· Registered
My ESS kit has been without problems for almost 5 months now.
It is fed engine-oil so when you change your oil, you clean the compressor's oil as well. Also, the Vortech units they use are designed to me as maintentance-free as possible and reliable.
Once installed, you shoulnd't have to touch it other than chaging your engine oil regularly, which we *all* do, right!!?!?!?
One of the main reasons ESS hasn't finished the Stage 2 kit is to get a solution that is as maintenance-free as possible, aka an air-to-air intercooler setup, not air-to-water or water/alcohol injection.
I like the fact that they tested these kits at higher boost, then turned it down a bit for reliability and drivability.
1 - 2 of 2 Posts
