Hey All. Let me start out by saying that I've scoured the forums, and have yet to find any detailed information on cutting open the fuel tank without dropping it, to access and remove the non-serviceable fuel pump in a SULEV e46, aside from Bali's recommendations on a few posts and one user's photo of his cut tank. I assume the lack of posts are due to the rarity of our SULEVs, other owners instead opting to do a full blown SULEV-ectomy. Or simply that this DIY job is so straightforward that any further explanation is not needed for others. Hopefully the lack of posts are not for the belief that this is incredibly dangerous and stupid...
Anyway, my EKPS module is throwing codes which I've read with INPA for "Fuel Pump Speed Too Low" with a frequency of 22. I have SES lean codes for Banks 1 & 2. I'm relatively confident that the fuel pump is going out. 2004 325ci 111k miles
I noted Bali's rec on prepping/ draining/ cleaning the fuel tank and his rec for the cutting procedure, but I can't help but ask for more information to feel comfortable, and to possibly help someone else in this situation.
If I do the DIY cut I'll be replacing the fuel pump motor with an m3 to match the SULEV pump specs, and plan on sealing it with gas tank sealer to make it serviceable in the future. I'd really like to replace the fuel filter also if, it's possible. However, the space to work in looks extremely tight.
Has anyone done this before and can offer advice?
The other option I would reluctantly consider is swapping in a non-sulev tank, m3 pump, m3 fuel filter, m3 fuel lines etc + whatever else I'm missing.. but id rather keep this project as straightforward (and cheap) as possible.
