1 - 13 of 13 Posts
Because Race...Convertible?
Turbo ZHP Convertible
I have a 04 330Cic with 117000. It is a ZHP, vert, driven with top always down, and i push it decently hard. So i get around 15.7 MPG. 91 Octane Fuel. Suddenly it has dropped to 14.4 and i can smell an odd burning smell at high revs from the front. CCV? I also seem to be burning a bit more oil than standard.
15.7 mpg isn't bad when "pushing it hard".
Yeah, CCV is the first thing I would be looking at.
Discussion Starter #3
Yeah it's not bad. But even after resetting mpg and driving extremely tame for a month it's the same. Think it's convertible drag
That, the extra weight and traffic can't be much better in OC, than it is here.
Discussion Starter #5
I recently lowered. Would that make any difference?
Lowering reduces drag at highway speed, so it could even positively affect mpg, but in normal driving has no effect.
Did you have aligned after you lowered it? You may have introduced additional camber/toe with the new suspension.
If you added heavier wheels and wider tires that also could contribute to the lower mpg.
Oil burning smell, check the valve cover gasket and the lower CCV hose.
Have you replaced the plugs recently? They are 100,000 mile maintenance items.
Discussion Starter #8
Plugs are fresh. Yes I may need an assignment, looks like front toe could be off. Valve cover is clean. Can I check that hose without taking everything apart
Discussion Starter #9
Bump. Any other thoughts here?
2006 330ci zhp
Try the crankcase vacuum test. With the engine idling, remove the oil cap and hold a piece of paper to the hole. Don't let the paper get sucked in but vacuum should be present and sucking on the paper. If no vacuum then you have a CCV problem.
Discussion Starter #11
I'll try again but last time I checked that with my hand I felt definite suction. Just a little.
Discussion Starter #12
Bump. Had a friend drive this who is quite proficient in e46s and he says vacuum leak maybe. Any responses to places to start? I do have a KN pod intake but this didn't start for 5 months after I'd had it
Discussion Starter #13
For people in this. I recently cleaned my maf and recalibrated throttle. It seems to have cleared the burning smell but still bad mileage. Could this be coolant related at all? Ive had strange coolant level and air issues
1 - 13 of 13 Posts
