Bought an O2 sensor socket set. It has 7 pieces. Had it for a long time never used it. I can only get 1 to fit properly out of the 7. Its a 22mm, but its a wingnut type look to it. I can post the image if you need to see it. The problem is its not a socket I'm trying to loosen from directly above it. The drive opening is off to the side of the o2 sensor. I can't get good leverage. I'm strong so that is not the problem.
I have heard people use a torch, or you have to run your car and get it really hot. I've used penetrating oil on it everyday as it sits. No go. The real hell is replacing the exhaust manifold if its baked in there and won't loosen.
I have thought of trying to find "extra" deep well sockets. I found one company that makes them but they are expensive. Since nothing that goes over the top will make the length to the bottom.
I have already cut the wire coming from the sensor so there is no worries about that.
I'm down to a "extra" deep well socket or they sell and adjustable head o2 sensor wrench that has some play.
Has anyone else ran into this problem? Please inform with any suggestions!
