1 - 4 of 4 Posts
ok I dont know what the real word is for them, but I have stripped the place where your lugs screw into, How do I fix this? Is there something I can buy to re thread it? I really have no idea. thanks
Slow in, slower out
You
are
[email protected]!
Which hub did you strip and how did you do it?
A front hub (actually a sealed bearing and hub assembly) can be replaced fairly easily. A rear hub is more difficult because removing the hub usually results in bearing damage so the bearing that is pressed into the control arm has to be replaced too.
Ed
Discussion Starter #3
oh man , its the rear, last time i went in they had to cut off my wheel locks & the guy sai they striped it & just re threaded the hole. I figured it would be easy. crap
1 - 4 of 4 Posts
