Hey guys... during a suspension install this weekend I managed to strip the 18 mm bolt that holds the strut to the housing. At first I tried to remove it with a socket and then tried a wrench. A wrench gave me more grip but it's too stripped now. It still grabs, its not rounded but definately some play in it.
What do you guys recommend?
I've done some research and seen suggestions to use vice grip pliers, maybe some deep creep or a grip-bolt socket to grab that sucker. It's really tight in there and who ever did the previous install did not put a washer between the bolt and the bracket. I tried lots of WD-40 but still no go.
I considered removing the sway link and trying to step on the rotor to release the control arm. Maybe this way I can release some pressure of the bolt and try to remove it then. (Not sure if this would work as I'm sure the bolt holds that pretty tight in there.)
This is the last corner needed for me to finish my installation.
I would want to avoid going the "bolt-extractor" route if possible as I don't have all the tools needed for that. Let me know what you guys think.
Thanks.
Thanks.
