1 - 13 of 13 Posts
Help, in the morning right after I start the car (325xi)I hear a whoosh, then a thud, then a light eeeeeeeee sound, that progressively gets louder and then softer then quits. The whole process take around two min. Have others on the board had this problem, or better yet, found out what the cause is. any help would be appreciated.
Invalid User
i think i get that sound. it only happens when the car is cold. it kinda feels like it has something to do with the clutch?? i have no clue. maybe it's just warming up... :huh:
Discussion Starter #7
the thing is, I'm taking the car in on friday and because it only makes the sound on the first start of the day I wory that it wont make the nois and I will have wasted the day.
Movin On Up
i get real stiff steering when its cold until the wheel gets a cranking a little bit...only other noise is an odd squeak from my trunk im thinking maybe my bushings are ****ed up...anyone got any ideas?
Mine squeels in the morning too
Yeah, I have the same problem. I'm taking it into the dealer to get it fixed. This will be the time time in for the same problem!
Mine makes squeaky sounds when i slowly let off the clutch and allow the car to move follow. It squeaks near when I"m almost off the clutch. The dealer can't seem to figure it out though, so I'm making them fix it, otherwise I don't want it back!
Big in Japan
If its an air noise, or could be an air noise, you may be hearing the air pump in the emissions system (pumps air into your exhaust manifold so excess fuel will burn in the cats and heat them up quicker)
Discussion Starter #13
Thanks for the help, Im taken her in of friday. I'll keep you posted on what they find.
1 - 13 of 13 Posts
