1 - 3 of 3 Posts
Does anyone know how to remove a non sport steering wheel on a 2000 328i. I'm trying to replace the turn signal stock because my obc button quit working. But I can't figure out how to remove it?
Thanks.
look for the 2 holes on each side on the back of the steering wheel and you would need a torque bit tool to remove them, i just dont remember the size, its pretty easy...just to warn you, make sure you disconnect the battery first before you unplug the airbag connectors, and plug them back in before you re-connect the battery.
Discussion Starter #3
I'm using a #27 torx driver, it seems to fit, but no matter how hard i turn it it will not budge and I know I'm turing it the right way but it won't move.
1 - 3 of 3 Posts
