I recently bought an e46 330i with 18 inch rims. The wheels in the back are wider (255 cm) than in the front (225 cm).
My steering wheel doesn't return to the center / middle position after a corner. Also, when I drive over a little ridge or something, the steering wheel + the wheels are kind of 'pulled away' from going straight and I have to manually get the steering wheel back to the middle again.
This makes for a pretty uneasy driving experience and doesn't give me the confidence to get the maximum cornering performance out of this car.
I took it to the garage and the guy said that everything is fine with the steering driveline. He said it's most likely because of the 18 inch rims in combination with the wider back wheels. He said changing to 17 inch and all 4 wheels the same size will fix these problems.
Could that be true? Or are there other things that should be looked at?
Thanks!
Thanks!
