This topic may have been covered already but I could not find anything recent when I searched.
There is a subtle clicking noise coming from the steering wheel when it is ever so slightly moved in either direction. The movement does not require the front tires to be moved. I did some research and from what I gathered, the noise was being caused by the steering coupling assembly represented by #2 in the picture below:
Steering coupling assembly
I had this replaced today and the clicking noise continues. Grrr!
I clearly replaced the wrong part. The only thing left to replace is the lower joint assembly (#1). Can anyone confirm if this will actually remedy the noise? I don't want to keep throwing money at this issue but I do want it gone because it drives me nuts!
Video of clicking steering wheel
Thank you in advance.
