Nothing changes, very low.What about floor and defrost settings?
No need to apologize, we were all new to cars at some point in time. I would suggest that you don’t simply pile on one problem after another in the same thread. Otherwise it’s really hard to follow, difficult for others to search and we end up with overlapping conversations. Lastly describe your problems clearly with details as that would get you the best responses.The air blowing from the interior A/C is very very weak so I’m guessing the fan blower. I was referring to such when I said nonexistent, I’m not yet familiar with the A/C system, my apologies.
That’s totally fine. I’m going to replace my fuel pump this week, that should fix the fuel pressure issue.No need to apologize, we were all new to cars at some point in time. I would suggest that you don’t simply pile on one problem after another in the same thread. Otherwise it’s really hard to follow, difficult for others to search and we end up with overlapping conversations. Lastly describe your problems clearly with details as that would get you the best responses.
With that, how about we keep this thread to be about your original problems?
Great, let us know how it goes. Posting the end result is very useful for everyone. The people who helped would get a sense of accomplishment because they helped someone. If it fixes the problem, then when the next person searches this forum, they would get everything they need to help themselves.That’s totally fine. I’m going to replace my fuel pump this week, that should fix the fuel pressure issue.
Fuel Filter: https://www.ecstuning.com/b-mann-parts/fuel-filter/13327512019~man/Brand of pump? Filter?
Mann filter brand is fine, URO pump brand is crap.
Genuine BMW is 400$ is that the only good one? Are there OE suppliers of a fuel pump assembly?Mann filter brand is fine, URO pump brand is crap.
Hell yes! How does $152 sound?Are there OE suppliers of a fuel pump assembly?
That’s great! Thank you!Hell yes! How does $152 sound?
BMW Fuel Pump and Sender Assembly - VDO 16146766942
BMW Fuel Pump and Sender Assembly - VDO 16146766942www.fcpeuro.com
To get free shipping im going to buy everything on fcp euro, so is this a good filter?Many recommend VDO.
How many bad coils you had? one bad coil wouldn't cause the engine to die.then would die a second after it started.
Not saying with 100% certainty that's what's causing your issues, but in my case it was a bad coil...
I got a brand new valve cover, coils, and spark plugs thinking it would solve my problems. Bad idea! Fixed nothing.
So what did you change that engine was not running and then now idling perfect? Obviously the low fuel pressure is not good.I have great and bad news.I doubled checked all my work but it still wouldn't start, checked fuel pressure while cranking it was 30 PSI. I cranked it then revved to 2k rpm for 10-15 secs turned it off then turned it back on and now its about 45 psi and idles perfectly,
I would use it.To get free shipping im going to buy everything on fcp euro, so is this a good filter?
BMW Fuel Filter With Fuel Pressure Regulator - Mahle 13327512019
BMW Fuel Filter With Fuel Pressure Regulator - Mahle 13327512019www.fcpeuro.com
Any of the three of Kayser, Mahle, Hengst are fine.buy everything on fcp euro, so is this a good filter?
