Who's had issues with this, how did you fix it?
Replaced flex joint on transmission and center support bearing repacked the CV joint got good tension on the bearing aka pre set. Drove for 6 miles test drive just fine. Then got back on the car and got the cog light, car went into limp mode only shifts to 3rd gear, no signs of vibration or clunks. I went to reset the adaptations and got shift travel sensor codes and engine output implausible. Cleared codes but now the car only going from r to 1 gear. Says it's in 1st gear but will only drive in reverse. Any ideas?
