1 - 12 of 12 Posts
I seem to have a squeeking nose come from the front of my car but it only happens when I turn left...any ideas?...there is no squeeking nose when breaking so I do not think it is the brakes...
I have that problem too recently. I know its hard but can you describe the type of squeek? Mine sounds like a wooden chair being drag on a tile floor.
I also have a creaking noise when turning right mostly. It sounds like a dry ball joint or tierod end. Could also be struts or strut mounts but mine are new. Could be rack or steering column joint. Will check it out shortly as brakes need to be done. It never ends!
i had a noise a while back and it was due to low power steering fluid...give that a check?
1 - 12 of 12 Posts
