1 - 8 of 8 Posts
Hi guys,
I've done some serious searching but can't find an answer to the following question:
Should I be replacing my spark plug connectors every X miles? or do they just need to be replaced if I am having a misfire or other issue? I've found mileage charts for the plugs and boots but nothing for the connectors.
My mileage is about 90k and they have never been replaced. I replaced the spark plugs at 60k but not the boots or connectors.
These are the only connectors I could find online (but in another thread somebody mentioned that these were recalled) if anyone knows where I can find the Bosch connectors, it would be much appreciated.
http://www.pelicanparts.com/cgi-bin...r from Coil to Spark Plug (sold individually)
Thank you very much in advance.
Banned
no need to replace your ignition coils and ignition boots unless it is giving you problems. just replace your spark plugs as normal
Im about to to a plug change and am going to be replacing these connector boots as well due to the fact I dont want to have to open up everything again for a couple of years at least. Its cheap insurance.
My routine is plugs at 60-70K, plugs and connectors at 120-140K. Probably could get away with going more miles and running until you have an issue. But, this is one maintenance thing I do before a problem comes up. On the other hand, my OE expansion tank is at 164K! Go figure.
For example: if your changing your plugs at let's say every 50,000 miles then you would change the connectors at a 100,000 mile interval. The plugs most certainly don't need that much of a change interval as the sparks would do but like other members have already stated, it's just cheap insurance. Up to you really..
Discussion Starter #8
Thanks for all the responses. I think I'm going to hold off on replacing the connectors for now.
Thanks again
1 - 8 of 8 Posts
