Hi everyone,
I just bought a used 2000 323Ci with 165kmiles a few month ago, and since I like the car I plan to do quite a bit of maintenance on it.
Basically I want to replace every gasket, hose, rubber or common failing part that I can, and that does not cost too much.
So here is the big question: While I have the car on stands and everything apart, what other part would you guys recommend me to replace and/or loot at?
What I plan to replace + part number:
DISA O-ring 11617504543
fuel filter 13321740985
fuel pump 16146766942
front wheel cover (near belly pan) broken 51718224986
intake manifold profile gasket 11611436631
Valve cover gasket 11129070990
VANOS seal and orings 11361433817
VANOS line +copper gaskets 11361705532
fan switch oring 13621743299
ICV Rubber grommet 11611437453
clean the ICV
voltage regulator 12311713491 (edit: Bosh, $400)
final stage resistor 64116923204
drive belt 11287636379
serpentine belt 11287636379
differential fluid
transmission fluid
coolant fluid
brake fluid
Eventually:
coolant system hoses? (not cheap for just tubes)
water pump? The one on the car is aftermarket, so it has been changed at some point, I just don't know when.
fuel injector cleaning (witch hunter)
Also, here is what I already replaced :
CCV and its 5 hoses (Frozen)
oil dipstick O-ring
filter housing gasket
battery
spark plugs + boots
camshaft sensor (triggered CEL)
MAF sensor (trigger CEL)
oil level sensor
throttle body gasket
Keep in mind that I am not that rich ATM, so anything not really worth it should not be included. Depending on the price, I might not even replace some of the above parts too.
Though, I would hate to take everything apart, put it back and realize I forgot to change that $3 O-ring/hose that can fail and is a PITA to change on its own.
Thank you for your input.
EDIT: Added cooling system overhaul (thanks markusmarkus)
clean the ICV
differential fluid
transmission fluid
coolant fluid
brake fluid
Eventually:
oil dipstick O-ring
battery
spark plugs + boots
oil level sensor
