Haven't posted on here in quite awhile, but my car is getting older (2004, ~180k) and more issues are coming up.
I've been having a problem with my bi-xenon headlights. They will intermittently turn off for a second or two, then turn right back on. It's never been both sides at the same time, but the passenger side seems to happen much more often. Occasionally this will occur enough times where the headlight will not simply come back on and the dash warning gets tripped. But it will light again by turning them completely off and then back on manually. At first it seemed like it only happened when I went over bumps but the problem seems to have gotten worse and will randomly occur when I'm driving on a smooth road as well.
I had a bulb go out about two years ago so I replaced the pair, I believe I settled on 5000K bulbs. Never had any issues until this fall, noticed it a couple months ago when the temps got colder here in Denver. The car gets parked outside on a driveway for all 4 seasons, always has been. Shouldn't affect the headlights.
After some searching I understand there are four main parts to the headlight system: (1) bulb, (2) igniter, (3) ballast, and (4) control module. My thinking is that it's unlikely the igniter since it doesn't seem to have any problems lighting, the issue is staying lit. I doubt it's the control module since all other headlight operation is good, the auto-tilt/turn/moving the lights do works and the light by the dash knob is always green. I wouldn't be surprised if it is the bulbs, but it'd be odd to have both going bad at the same time and I haven't noticed a change in light output since the issue has started. If I had to replace bulbs, I would go back to the factory OEM 4300K bulbs since I haven't been all that impressed with different temp bulbs.
Now, I've read several threads on people replacing ballasts to no avail (and they also seem quite pricey). I stumbled across this but the price seems too good to be true (if it is in fact legit OEM replacement parts):
https://www.headlightexperts.com/ca.../520/s/headlight-experts-al-bosch-d13a5-oem-new-replacement-ballast/category/2/
I've also read about potential grounding issues in the tail lights somehow affecting the xenon headlights. In Dec 2016 I replaced my LED tail lights with a set of smoked DEPO brand (I was in college, they were cheap, and I actually like the look...). There's some kind of resistor/capacitor pack on the inside-of-the-trunk portion that never really got put together. Everything worked as I had it so I didn't think anything of it...not sure if that could be related in any way. But it would be strange if that is only now causing the problem after a few years.
For the record I also have a fog light burned out but I don't think that would affect the xenon headlights.
I plan on getting under the hood and checking electrical connections and whatnot this weekend. Just wanted to get thoughts on what might be the issue. It's been a nuisance up to now, but I feel like it's getting worse and I don't want the lights going out all together while driving after dark. Especially with an 10+ hour drive home for the holidays coming up soon...
Thanks in advance!
Thanks in advance!
