1 - 1 of 1 Posts
**Sold, please remove***
Selling my daily driver '04 325i with 147k miles. I've repaired just about everything that needs it at this mileage with everything done listed below. Owned for 3.5 years and loved this car to pieces but I'm moving across country and can't take it with me. Mild update to audio system with bluetooth headunit, polk components in front and coaxial rears. Rear amp is replaced by a Hifonics 4-channel using a custom adapter. Nothing was cut or modified and the included OEM system can go right back in. Located in NW Ohio, no shipping. No packages. VIN WBAET37484NJ81801
$4000 OBO
Upgrades:
-Akebono ceramics in front
-Meyle HD front control arms, poly bushings
-DISA valve reinforcement kit
-Cold Weather PCV valve and hoses retrofit
-Aluminum power steering pulley
Work Done: (Receipts for everything)
-New Front driver brake caliper
-Bosch Rear Pads
-New Rotors all around
-Full system brake fluid flush
-Parking brake shoes
-Upgraded front control arms and polyurethane bushings
-Coolant reservoir
-Complete Coolant flush, BMW coolant
-Upper and lower radiator hoses
-Pressure-reducing radiator cap
-Water pump and thermostat
-Intake tubing, both front and rear
-Intake filter
-Upgraded DISA Valve
-Front swaybar endlinks
-Full alignment at 144k miles
-Cleaned Throttle body, idle control valve
-Cold Weather Crankcase vent system
-Valve cover gasket
-Oil filter housing gasket
-Iridium spark plugs
-Full synthetic oil, BMW rated, 5-8k mile intervals, Total INEO or Mobil-1
-New power steering pump and reservoir
-Upgraded aluminum power steering pump pulley
-New accessory and AC belts
-New accessory idler and tensioner
-Power Steering Fluid flush
-Fuel filter
-Cabin filter
-Emblems, hood and trunk
-Front driver door replaced under BMW Paint warranty, Yark BMW
-Driver kick panel and rear bumper resprayed, paint warranty
-New all-season tires at 110k miles
-Euro-spec heated side mirror glass
-Paint is clayed and waxed
-New dead pedal
-Flushed rear differential
-New battery with warranty
Comes with OEM stereo parts, extra coolant, accessory belt, fan clutch wrench, oil filter socket, caliper bolts, rotor bolts, and Beisan VANOS repair kit i never got around to install.
1 - 1 of 1 Posts
