1 - 13 of 13 Posts
so i am thinking the oil pump gave out(had to be that damn nut) or a rod or both.
this sucks was driving home last night.
any info on a upgrade oil pump :cry::cry::cry:
how does that happen? What did it sound like when it happened? Did you also have to change your underpants?
Discussion Starter #8
idk i was driving up heard a pop then lights blinking then car dies so i just leave it there half way up my drive way and half in the street till i can look at it in the morning. morning comes it starts and runs all the way up to the driveway then i cut it off and look back a stream of oil. and thats where its at now
2006 330ci zhp
It's on the pan and I can see the sprocket and I can wiggle it it moves alot right above the hole is the pump.
So the sprocket cam loose and broke the oil pan? You are lucky it waited till you got home to break loose instead of stranding you out in bf egypt.
Discussion Starter #11
:facepalm::facepalm:well looks like i need a new motor pulled the plug out of cyl.1 and pushed the piston down with my extension rod broke.:facepalm::facepalm::thumbdwn::cry:
1 - 13 of 13 Posts
