1 - 9 of 9 Posts
Should i get 205's or 225's all around or get 205's for the front and 225's in the rear? any help would be appreciated.
Discussion Starter · #4 ·
I'll def do 225 in the rear, but should i do 205 or 225 in the front? What will the difference be in these 2 setups?
Basically comes down to tire selection. If you want maximum snow capability but still want to use H rated snows, I'd go 205/50 on the front. If you want the maximim snow traction and are willing to use the Q rated tires, I'd go with Blizzak WS-50 with 225/45R17 all around. This is the setup that the former moderator, Eddie, used on his 330CI last year and he loved the results.
Discussion Starter · #6 ·
I'd use h rated snow tires, as the snow isn't too bad here. With this being the case, you'd recommend 205 in the front and 225 in the rear?
winter tires
I am using on my M68 goodyear ultragrip GW2- made in germany.
225-45-17 all around.
if you need the report of that tire compare to bridgestone or michelin let me know.
you could be surprised.
thanks
1 - 9 of 9 Posts
