1 - 6 of 6 Posts
I used to be able to push the lever forward on S6 and stomp on the gas and when I let go to launch it'd peel out for a bit. But now I don't peel out and i just start going. What's up with that?
HKE46Boy said:
how do u use the launch control? I still can't figure it out!
:D step 1 :D
Buy M3
step 2
Sorry HKE46Boy couldn't resist.....................I am still stuck on step 1
TheOnlyConstantIsChange
You pull the paddle toward you and hold your foot on the gas, then you let the paddle go and keep your foot on the gas, is it that hard. :dunno:
Bimmerless
ABSOLUTELY WRONG!
1. DSC OFF
2. S6 mode
3. Push STICK forward (away from you)
4. Floor it (make damn sure no one is infront of you, JUST IN CASE)
5. Revs should go to 1800 rpms
6. Let go of lever
I wouldnt recommend doing this TOO often, not really good for the tranny.
MAKE SURE noone around you. I have tried it several times;u have to hold your steering wheel tight coz the rear will kind of spinning.
1 - 6 of 6 Posts
