Hi, everyone just trying to get some ideas of why the car wouldn't start.
I want to start by saying the clutch switch is wired up and I am 99 percent sure it is correct. However, I have not done any of the reprogramming as of yet because my software is unable to access my ms45.1.
In the past, my car had a very similar issue, didn't crank or start, so I thought has to be the starter right? The next day a noticed a fuse in the engine bay compartment was slightly lifted up, pushed it in and it started, after some more digging It appeared to be SMG/SSG specific (20amp in my case, 30amp for an m3 SMG) To which I believe was for the gear position sensor. Knowing this, would the programming just eliminate my problem, or should I do some sort of ews delete as well.
Also, I do not have the sensor on the side of my gs37bz wired up, but I believe that is just for the reverse light (correct me if I'm wrong but it is not necessary correct?)
As far as the software side of things, the process I need to delete is process 206, so that the dme does not look for the SMG/SSG TCM, and then to reset adaptations for that module (I think that is all I need to do)
I live in Florida, so if there is anyone who codes on ms45.1 let me know, and any information would be helpful.
