1 - 9 of 9 Posts
How would I go about changing the brake pedal on my auto (wide style pedal) to the brake pedal from an SMG or Manual car? Is it a direct swap??? I want my pedals to look/feel like those in SMG and Manual cars:D
Discussion Starter #3
but if i buy a pedal kit or just the clutch/brake pedal from a manual, will it screw into my brake lever?
needs a new sig...
of course..the brake pedal is steel..youll need to use a dremel with a bit that can cut metal to cut the size down..then a tungsten bit to drill 4 holes..really easy
Discussion Starter #5
I want a factory pedal from a manual car. Will this pedal be a direct replacement to my factory one? I dont want to have to cut my regular pedal down. What I am trying to say is: If i take off my brake pedal and buy a pedal from an SMG or Manual car, can I just attach it to my existing mount? :dunno:
Help!:banghead: :banghead:
TheOnlyConstantIsChange
No you'll have to cut it down. And I don't know why you would want to have a little brake pedal if you have an auto.
he is not talking about the rubber pad and the plate behind it, this is the real question:
"can I remove the entire Brake Arm from the mounting at the Firewall, and replace it with a Manual assembly?"
I would guess that there would be no reason why this could not be done, but I would also bet that the cost and time involved would be prohibitive!
not worth it IMO.
1 - 9 of 9 Posts
