1 - 5 of 5 Posts
do you have an m3 ?
Anyways, you put your foot on breaks, put in key to 1 or 2 position, and put your gear in neutral, don't leave it in 1st gear or reverse, which will not let you turn on the engine.
turn on engine while your foot is on break.
all correct, the car does not start in gear and wont change to neutral without your foot on brake, if you try to start it in gear, then you have to turn the key again to start. You can with key turned for ignition, put it into neutral and the car will start. The car also does not park in neutral, it gives beeping noise for you to put in neutral and will do it by itself if you leave it in neutral.
1 - 5 of 5 Posts
